W5100 Ethernet Chip SPI code
tkjmail2
Posted on June 21, 2010 at 17:30
3 REPLIES 3
Andrew Neil
Evangelist III
Posted on May 17, 2011 at 13:55
''it doesn't go very well''
What, exactly, do you mean by that?
tkjmail2
I doesn't get any sign of life from it...
So maybe the SPI isn't set up properly or maybe it's just me that haven't ported it correctly.
I've uploaded the code - keep in mind that it is a mix of my fully working LCD library/interface which I use for debugging, and the not working ported W5100 code!
Download it here: http://elec.tkjweb.dk/SSD1963_W5100.zip
Best Regards
Thomas Jespersen
Andrew Neil
Evangelist III
''I doesn't get any sign of life from it... So maybe the SPI isn't set up properly''
Have you checked with a scope that the clock is being generated?
And any required chip select?
And data on the data lines?
