2025-03-20 6:45 AM
I am studying the architecture of the STM32H7 family, and according to the AN there are various types of memory, DRAM, SDRAM, NOR/PSRAM, NAND in addition to the swap between SDRAM and NOR/PSRAM.
What is the reason for such diversity and what benefits does this bring to the developer and the system?
2025-03-27 6:45 AM
The diversity of memory types offers flexibility and allows the system to be optimized according to the needs.
Here is an explanation for each type of memory:
DRAM (Dynamic Random-Access Memory)
SDRAM (Synchronous Dynamic Random-Access Memory)
NOR Flash
PSRAM (Pseudo-Static Random-Access Memory)
NAND Flash
The Utility of Swapping between SDRAM and NOR/PSRAM
Swapping can be used to optimize memory management and improve system performance.
Here is an explanation of this concept:
Performance Optimization
Efficient Memory Management
Improved Reliability
Thank you.
ELABI.1
2025-03-27 6:45 AM
NOR Flash
NAND Flash
Thank you.
ELABI.1
2025-04-10 10:48 AM
Thank you, your explanation was very helpful.
