Using the G431RB mounted on the Nucleo board.
Can't port the example code for TIM2 pwm output to TIM1???
‎2020-07-31 03:32 PM
STM32Cube\Repository\STM32Cube_FW_G4_V1.2.0\Projects\NUCLEO-G431RB\Examples_LL\TIM\TIM_PWMOutput
This project runs fine. However, it uses TIM2. I tried to port to TIM1 so I could be interrupted every 10 periods, rather than have to count them in an isr. I did allthe obvious things. Any tricks? My project outputs nothing. I relocated to PA1 from PA5, and made the required changes. No go. What additional init is required for TIM1 that is missing from TIM2?
STM32G4 Series
TIM
‎2020-07-31 05:57 PM
SET_BIT(TIM1->BDTR, TIM_BDTR_MOE);
‎2020-07-31 03:56 PM
For TIM1, the TIMx_BDTR_MOE bit needs set to have a PWM output. Only advanced timers (TIM1/TIM8/TIM20) have this bit.
‎2020-07-31 04:05 PM
+1
And TIM2 being 32-bit vs TIM1 16-bit on many STM32
‎2020-07-31 04:07 PM
If you need to see my version of attempting to port to TIM1, let me know please.
‎2020-07-31 04:44 PM
Well the MOE bit is the only gotcha. So if it's not that, you have something basic wrong.
‎2020-07-31 04:53 PM
Thanks guys. As a long time fan of the Three Stooges (Larry, Curly, and Moe), I should of known!
Once I validate that this is the only Gotcha, I'll update.
These short acronyms get me everytime.
‎2020-07-31 05:41 PM
I must be using the wrong include files. Same ones as for TIM2 probably don't work for TIM1? No signs of MOE or TIMx_BDTR
‎2020-07-31 06:00 PM
Definitely defined in the CMSIS include file:
