using a timer to count pulses on STM32F7
spa23
Posted on November 08, 2017 at 10:50
Hi
I have a question about using a timer to count pulses form a encoder (only one pin) I don't care about the direction.
I'm trying to use Timer 3, but I'm not sure how to set it up in CubeMx.
I start it with:
HAL_TIM_Base_Start( mpEncoderTim );
And read with:
count = mpEncoderTim->Instance->CNT;
Hope anyone of you, have done this before, so you can give me a hint
thanks in advance and best regards
panduro..
#stm32f7-timer
spa23
Posted on November 08, 2017 at 13:22
I think I solved the case.
Counter Period was 0 :(
4 REPLIES 4
Posted on November 08, 2017 at 11:03
On TIM13 you can't - it does not have the slave mode controller needed for external counting modes.
Look into RM, search for SMCR register, look at its SMS field.
spa23
Posted on November 08, 2017 at 11:17
sorry for my mistake I meant Timer 3
Posted on November 08, 2017 at 11:40
I don't use CubeMX nor Cube.
You want to set TIMx_ARR (I guess it's what is called there 'period') to nonzero.
spa23
