USB Virtual Com Port buffer overflow
camille
Posted on January 09, 2012 at 10:09
Hi everybody.
I've a remark to do about the ''USBD_GetString(uint8_t *desc, uint8_t *unicode, uint16_t *len)'' function defined in ''usbd_req.c''.
When it's called with the function ''USBD_GetString (USBD_PRODUCT_FS_STRING, USBD_StrDesc, length);'' in ''usbd_desc.c'',
the reserved size of ''USBD_StrDesc'' in memory is 50 : ''__ALIGN_BEGIN uint8_t USBD_StrDesc[USB_MAX_STR_DESC_SIZ] __ALIGN_END ;'' in ''usbd_req.c''
with following define in ''usbd_conf.h'' :  ''#define USB_MAX_STR_DESC_SIZ            50''
However the ''USBD_PRODUCT_FS_STRING'' is define in ''usbd_desc.c'' as ''#define USBD_PRODUCT_FS_STRING          ''STM32 Virtual ComPort in FS Mode'' '' so it's a string of 32 characters.
When USBD_GetString(...) is called it converts an ascii string to unicode string so doubles the size of the string and adds its length at the beginning. So for a string of 32 chars a size of 66 chars have to be reserved, that is 16 more than it is.
I don't know who alert about this little mistake but for me it has been a pain because it overflowed over data I used in my main application. So if it can help someone in the same case I post it.
Regards.
Robin.
igal
Posted on July 28, 2013 at 12:35
Thank you very much, it helps a lot
I use this driver for ages now and only today I found that overflow myself, it went under the radar till today
alyoshin
Posted on February 20, 2017 at 07:01
Date: Mon, 20 Feb 2017 08:52:56 +0300
Subject: [PATCH] Limit string length with USBD_MAX_STR_DESC_SIZ in
 USBD_GetString()
 Middlewares/ST/STM32_USB_Device_Library/Core/Src/usbd_ctlreq.c | 9 ++++++---
 1 file changed, 6 insertions(+), 3 deletions(-)
diff --git a/Middlewares/ST/STM32_USB_Device_Library/Core/Src/usbd_ctlreq.c b/Middlewares/ST/STM32_USB_Device_Library/Core/Src/usbd_ctlreq.c
index 7701a6d..d355903 100644
--- a/Middlewares/ST/STM32_USB_Device_Library/Core/Src/usbd_ctlreq.c
+++ b/Middlewares/ST/STM32_USB_Device_Library/Core/Src/usbd_ctlreq.c
@@ -733,13 +733,16 @@ void USBD_GetString(uint8_t *desc, uint8_t *unicode, uint16_t *len)
   uint8_t idx = 0;
-  if (desc != NULL)
+  if (desc != NULL)
-    *len =  USBD_GetLen(desc) * 2 + 2;
+    *len = USBD_GetLen(desc) * 2 + 2;
+    if (*len > USBD_MAX_STR_DESC_SIZ)
+        *len = USBD_MAX_STR_DESC_SIZ;
     unicode[idx++] = *len;
     unicode[idx++] =  USB_DESC_TYPE_STRING;
-    while (*desc != '\0')
+    while (*desc != '\0' && idx < *len - 1)
       unicode[idx++] = *desc++;
       unicode[idx++] =  0x00;
2.1.4
