USB Device Library documentation
licencje1
Posted on August 24, 2014 at 14:11
Does any documentation or doxygen exists for USB device library (exacly for HID)?
I try to deal with that library but I couldn't find any documentation which might explain me what are proper function used for.
Thanks in advance.
#usb-library-documentation
4 REPLIES 4
waclawek.jan
licencje1
Posted on August 24, 2014 at 14:57
This document doesn't contain very important description of function like: USBD_LL_PrepareReceive. I managed at external online blog pages that this function in important to receive data from usb. But this function is NEVER mentioned in file presented by your link...
waclawek.jan
Posted on August 24, 2014 at 15:23
Oh, so you are talking about the ''Cube'' library. It always helps if you start with describing what you want.
http://www.st.com/st-web-ui/static/active/en/resource/technical/document/user_manual/DM00108129.pdf
''Cube''-related questions should be posted in the dedicated ''software tools'' sub-forum, https://my.st.com/public/STe2ecommunities/mcu/Lists/STM32Java/AllItems.aspx
licencje1
Posted on August 24, 2014 at 16:30
I have no idea that these library are different, do you know why?
Or which one is better?
