USART3 at 7E1 problem
iagenjo
Posted on February 10, 2011 at 08:35
Posted on May 17, 2011 at 14:24
''It 's not defined the option USART_WordLength_7b''
Are you sure that the hardware supports it?
What does the Datasheet/User Manual say?
Do you think USART is correctly programmed for 7E1 conditions?
No.
Parity might appear to ''work'' for about half the bit patterns, and the stop bit is a problem. Once the receiver registers a parity error, that needs to be cleared before more data arrives.
You'd be better to program the USART as 8N1, and create the ''parity'' bit in software (ie  7+1 bits = 8 bits)
