2011-02-09 11:35 PM
USART3 at 7E1 problem
2011-05-17 05:24 AM
''It 's not defined the option USART_WordLength_7b''
Are you sure that the hardware supports it? What does the Datasheet/User Manual say?
2011-05-17 05:24 AM
Do you think USART is correctly programmed for 7E1 conditions?
No. Parity might appear to ''work'' for about half the bit patterns, and the stop bit is a problem. Once the receiver registers a parity error, that needs to be cleared before more data arrives. You'd be better to program the USART as 8N1, and create the ''parity'' bit in software (ie 7+1 bits = 8 bits)
