Usart TX with DMA : it doesn't send all buffer data
Thomas Lotz
Posted on September 14, 2017 at 11:35
I try to use Usart Tx with DMA on a STM32L052K6, in order to send a string
without needing to send each character independently.
I don't use ISR. The Usart TX works well without DMA using HAL functions.
The problem : when I call my function UsartTxData, there is only 2 bytes that are transferred, whereas my string is 13 characters. I've checked with debugger that CNDTR is correctly loaded to the value 13.
As soon as TCIF = 1, there is only 2 bytes transferred instead of 13, I've check Tx signal with oscilloscope.
I can not find out the problem, can you please help me ?
Thanks !
Thomas
Main  :
char msg[20] = 'page keybd   ';
#define BUFFER_SIZE        50
char TxBuffer[BUFFER_SIZE];
while(1)
    UsartTxData(msg);
    for(i=0;i<1000000;i++) RestartWdt();  // Delay
void UsartInit(void)
    GPIO_InitTypeDef GPIO_InitStruct;
    // Peripheral clock enable
    __USART1_CLK_ENABLE();
    // USART1 GPIO Configuration
    // PB6     ------> USART1_TX
    // PB7     ------> USART1_RX
    GPIO_InitStruct.Pin = GPIO_PIN_6|GPIO_PIN_7;
    GPIO_InitStruct.Speed = GPIO_SPEED_HIGH;
    GPIO_InitStruct.Alternate = GPIO_AF0_USART1;
    // DMA controller clock enable
    RCC->AHBENR |= RCC_AHBENR_DMA1EN;
    // Remap DMA channel2 on USART TX
    DMA1_CSELR->CSELR |= 0x011 << DMA_CSELR_C2S_Pos;
    // Configure the peripheral data register address
    DMA1_Channel2->CPAR = (uint32_t) (&(USART1->TDR));
    // Configure the memory address
    DMA1_Channel2->CMAR = (uint32_t)(TxBuffer);
    // Memory to memory transfer
    DMA1_Channel2->CCR |= DMA_CCR_MEM2MEM;
    // Memory increment mode enabled
    DMA1_Channel2->CCR |= DMA_CCR_MINC;
    // Data transfer direction, Read from memory
    DMA1_Channel2->CCR |= DMA_CCR_DIR;
    huart1.Instance = USART1;
    huart1.Init.BaudRate = 9600;
    huart1.Init.WordLength = UART_WORDLENGTH_8B;
    huart1.Init.StopBits = UART_STOPBITS_1;
    huart1.Init.Parity = UART_PARITY_NONE;
    huart1.Init.Mode = UART_MODE_TX_RX;
    huart1.Init.HwFlowCtl = UART_HWCONTROL_NONE;
    huart1.Init.OverSampling = UART_OVERSAMPLING_16;
    huart1.Init.OneBitSampling = UART_ONEBIT_SAMPLING_DISABLED;
    huart1.AdvancedInit.AdvFeatureInit = UART_ADVFEATURE_NO_INIT;
    HAL_UART_Init(&huart1);
    // DMA USART TX Enable
    USART1->CR3 |= USART_CR3_DMAT;
void UsartTxData(char *data)
    // Check if Tx DMA is busy
    if(UsartTxBusy() == 1) return;
    // Clear status / interrupt flags
    DMA1->IFCR |= DMA_IFCR_CGIF2 | DMA_IFCR_CTCIF2 | DMA_IFCR_CHTIF2 | DMA_IFCR_CTEIF2;
    // Set transfer data size
    DMA1_Channel2->CNDTR = strlen(data);
    // Copy data to buffer
    strcpy(TxBuffer, data);
    // Set busy flag (used in UsartTxBusy())
    TxBusyFlag = 1;
    // Channel Enable - start transfer
    DMA1_Channel2->CCR |= DMA_CCR_EN;
uint8_t UsartTxBusy(void)
    if((DMA1->ISR & DMA_ISR_TCIF2) != 0)
        TxBusyFlag = 0;
        DMA1_Channel2->CCR &= ~DMA_CCR_EN;
    return(TxBusyFlag);
Posted on September 14, 2017 at 14:30
This is your peripheral trigger.
11 REPLIES 11
Posted on September 14, 2017 at 12:34
Pity this isn't posted in a compilable form.
Wouldn't memory to memory just blast the register rather than being properly constrained by TXE?
Posted on September 14, 2017 at 12:52
PS. Oh Clive beaten me again :)
Thomas Lotz
Posted on September 14, 2017 at 12:55
Thanks for your reply
If I remove the memory to memory bit DMA1_Channel2->CCR |= DMA_CCR_MEM2MEM;
no message is sent
by usart.
Thomas Lotz
Posted on September 14, 2017 at 13:55
The datasheet :
The DMA channels can also work without being triggered by a request from a peripheral.
This mode is called Memory to Memory mode.
In my application, the DMA works without peripheral trigger, so the MEM2MEM seems to be right.
Posted on September 14, 2017 at 14:47
I might have spotted it:
You meant 0b011 rather than 0x011.
Posted on September 14, 2017 at 13:01
You want memory to peripheral.
Thomas Lotz
Posted on September 14, 2017 at 15:20
Yes it is a mistake,
I corrected it.
The trigger is DMAT right, it works
It solve the problem.
Sorry for that mistake, and thank you for your help !
Posted on September 14, 2017 at 13:47
Yes memory to peripheral.
But when I enable DMA channel, nothing happens, and I don't know how to
start the transfer by another means
. In case of peripheral to memory (like usart Rx) it is the peripheral that enable the DMA transfer, in case of memory to memory
the transfer is initiated by the activation of the channel
, but in case of memory to peripheral I don't know.
No, in your application you are jamming data into the transmit register giving you a depth of two characters, ie one shifting, one holding.
Make sure you're using the right DMA/CHANNEL for the USART in question. Review the Reference Manual, don't have access to it on phone.
