USART-5 on STM32 LoRa
sgabran
Hi
We are using the DISCO-L072CZ-LRWAN1.
USART-5 uses pin PB3 for Tx, is this pin not available on the LoRa development kit ?
Is there a way to re-route the USART-5 Tx pin or access it ?
thanks
RhSilicon
Lead
UM2115:
The B-L072Z-LRWAN1 Discovery kit embeds the CMWX1ZZABZ-091 LoRa®/Sigfox™
module (Murata)
Apparently this pin (PB3) is not available:
2 REPLIES 2
RhSilicon
Lead
UM2115:
module (Murata)
Once upon a time I made a post highlighting all the pins, but the forum transition seems to have destroyed that. There are about 3 escapable UART as I recall. You might have to split a UART to get both TX and RX from different ones.
There's a finite number of pins on the WLCSP and escaping from the Murata module.
PB3 is used internally for the Radio's SPI connection
