Unkown signa in Keil logical analyzer
Linda
Posted on March 29, 2015 at 03:16
I am using Keil 4, I want to set up Logic Analyzer in debug mode using simulator to check the output of GIOP
I had tried to key in GIOPA.0, PORTA.0, GPIOB_ODR.13, GPIOB_IDR.13 and so on, it return ''Unkown signal�?
Please help.
Thanks a lot
1 REPLY 1
Rashad Shubita
Posted on January 18, 2018 at 13:45
Please anyone can help us! I read various documentation such as :
http://www.keil.com/support/man/docs/uv4/uv4_db_dbg_logicanalyzer.htm
http://www.keil.com/support/man/docs/uv4/uv4_db_dbg_logicanalyzer_setup.htm
http://www.keil.com/support/man/docs/uv4/uv4_db_dbg_logicanalyzer_restrictions.htm
http://www.keil.com/support/man/docs/uv4/uv4_db_exp_periphlvar.htm
Using ST-Link/V2 and MDK 5 with Discovery/Nucleo Boards
but the same problem appears!
Thanks in advance.
