unexpected waveform in Examples/OPAMP/OPAMP_PGA/ in G4 package
HDaji.1
Senior
I try to learn how to use OPAMP by testing the example code Examples/OPAMP/OPAMP_PGA/.
The MCU board is Nucleo-G431RB.
0693W00000DntA6QAJ.jpgThis is the case of OPAMP_PGA_GAIN_2_OR_MINUS_1: blue line is output by DAC and red is by OPAMP.
My 1st question: why the amplified signal is distorted. Isn't it supposed to be another sine wave?
0693W00000DntCRQAZ.jpgThis is the case of OPAMP_PGA_GAIN_4_OR_MINUS_3.
My 2nd question: the amplitudes of the amplified signal seem not matching the gain.
Once the gain >= 8, the amplified signal becomes almost straight line. I also wonder why.
I want to modify the example code: I want to route the OPAMP output internally to a ADC channel. What steps I need to do?
12 REPLIES 12
HDaji.1
Senior
Dear @Igor Cesko​
I have another question:
0693W00000FARNMQA5.jpgThe above pic shows the signals captured from DAC and OPAMP output pins: blue is DAC; red OPAMP.
What puzzles me is their amplitudes: DAC output is from -40mv to 40mv; while OPAMP output is -0.8v to 0.8v. The gain is 20 times, but for OPAMP PGA setting is
  hopamp3.Init.PgaGain = OPAMP_PGA_GAIN_2_OR_MINUS_1;
@Igor Cesko​ sorry, my fault. The two probes themselves have 2 different gains: x1 & x10, so now everything makes sense.
Thx.
Check your measurments. Looks like you have wrong osciloscope probe configuration in you SW (10x vs 1x).
