UM0462 Flash loader demonstrator - Where?
John F.
Senior
Posted on November 23, 2010 at 15:23
4 REPLIES 4
Posted on May 17, 2011 at 14:15
http://www.st.com/internet/mcu/product/216817.jsp
Design Support -> SW DEMOS (Bottom end of page)
http://www.st.com/internet/com/SOFTWARE_RESOURCES/SW_COMPONENT/SW_DEMO/um0462.zip
John F.
Senior
Thankyou. I'm still getting to grips with the new pages.
zingsb1
Posted on March 05, 2013 at 22:32
clive1, I'm looking at the version history for version 2.5.0 and would like to learn a little more about the following items:
    + Fix of RTS and DTR Outputs control in Command line version
    + Fix of writing extra bytes at end of flash pages
Could you (or someone else) clarify or further explain these particular fixes?
Posted on March 06, 2013 at 00:19
I don't work for ST, and have no responsibility for this code. Suggest you diff/merge available sources to understand the code changes as they relate to you.
The changes relate to the demonstrator app, not issues with the ROM based system loader.
RTS/DTR probably relate to RS232 control pins, and there application to test fixture control signals.
The flash overwrite could well relate to Intel/Motorola HEX processing and a mis-estimation of data length.
