UART_Mutex not working properly!
Mujtaba
Dear friends,
I've created a UART mutex and when threads only send data over uart, everything works fine but when it is time to also receive data, after a while data is corrupted and the information is wrong and no data is valid!
		if( osMutexWait(modbus_com1_mutex_id, MAX_MODBUS_MUTEX_TIMEOUT_MS) == osOK)
			  DE_SIGNAL_1_GPIO_Port->BSRR = DE_SIGNAL_1_Pin;
				HAL_GPIO_WritePin(LED_1_GPIO_Port, LED_1_Pin, GPIO_PIN_RESET);
				HAL_UART_Transmit(&HAL_UART_COM1_HANDLE, txBuff, (txSize + 2), 20);
				DE_SIGNAL_1_GPIO_Port->BSRR = (uint32_t)DE_SIGNAL_1_Pin << 16U;
				HAL_UART_Receive_IT(&HAL_UART_COM1_HANDLE, rxBuff, rxSize);
				mb_rcvd = MH_MB_WaitforRespond(MH_MB_TIMEOUT_VALUE, COM_1);
				if(mb_rcvd == MH_MB_OK)
					HAL_GPIO_WritePin(LED_1_GPIO_Port, LED_1_Pin, GPIO_PIN_SET);
					rcv_check = MH_Mod_RTU_Receive_Check(rxBuff);
					if(rcv_check == MH_MB_OK)
						osMutexRelease(modbus_com1_mutex_id);
						return MH_MB_OK;
   /* Transmit data over RS485 media */
    /* Wait for the slave module to respond */
        /* Check if received data is valid */
		return MH_MB_OK;
Above is some part of the code related for handling the mutex and uart resource.
I'll be happy if anyone could help me with this problem.
Best regards,
Mujtaba
1 REPLY 1
Pavel A.
Evangelist III
Does MH_MB_WaitforRespond() wait for completion of HAL_UART_Receive_IT?
In case of RX timeout (mb_rcvd != MH_MB_OK) will it properly cancel the operation?
-- pa
