UART communication problem between Raspberry Pi 4 and STM32F767ZI
‎2022-02-04 7:02 AM
Hello everyone,
I'm trying to debug a problem with the UART communication between the raspberry pi 4 and an STM32.
Indeed, I try to send the number 1 from the raspberry pi to the stm32 but I can't get the right result.
Here is the code I implemented on the raspberry pi 4 :
import serial
from time import sleep
ser = serial.Serial(
port = "/dev/ttyS0",
baudrate = 9600,
parity = serial.PARITY_NONE,
stopbits = serial.STOPBITS_ONE,
bytesize = serial.EIGHTBITS,
timeout = 1
data = 1
while True:
data_str_list = [str(data)]
send_string = ','.join(data_str_list)
ser.write(send_string.encode())
sleep(1)
Here is the STM32 code :
char data_sign[1];
int main(void)
HAL_Init();
SystemClock_Config();
MX_GPIO_Init();
MX_DMA_Init();
MX_USART3_UART_Init();
MX_DAC_Init();
MX_UART4_Init();
MX_TIM6_Init();
while (1)
/* USER CODE END WHILE */
/* USER CODE BEGIN 3 */
HAL_UART_Receive(&huart4, data_sign, sizeof(data_sign), 1000);
/* USER CODE END 3 */
static void MX_UART4_Init(void)
huart4.Instance = UART4;
huart4.Init.BaudRate = 9600;
huart4.Init.WordLength = UART_WORDLENGTH_8B;
huart4.Init.StopBits = UART_STOPBITS_1;
huart4.Init.Parity = UART_PARITY_NONE;
huart4.Init.Mode = UART_MODE_TX_RX;
huart4.Init.HwFlowCtl = UART_HWCONTROL_NONE;
huart4.Init.OverSampling = UART_OVERSAMPLING_16;
huart4.Init.OneBitSampling = UART_ONE_BIT_SAMPLE_DISABLE;
huart4.AdvancedInit.AdvFeatureInit = UART_ADVFEATURE_NO_INIT;
if (HAL_UART_Init(&huart4) != HAL_OK)
Error_Handler();
When I send 1, I get this with the STM32 debug:
Sometimes, the value is 241 but I don't know how to interpret this data. Can you please help me please? I think it's a problem with the data types but I tried to change them but I still can't find the right result.
I also changed the clock frequency of the STM32 but nothing changes. The function HAL_UART returns 0.
STM32F7 Series
UART-USART
‎2022-02-04 7:43 AM
Hello @ChristenTen​ ,
Raspberry PI 4 UART Levels for RX/TX are 0V to 5V and STM32 levels are from 0V to 3.3V.
You need a level shifter to secure communication from STM32 to rasberry PI4. Make sure that you use PIO that are 5V tolerent also.
When PI4 doinx a TX the characters received by STM32 should be undersood.
Try to perform a loopback (shortcut between TX & RX) on STM32 first to be sure the UART is working fine.
BR,
Bruno
‎2022-02-04 9:07 AM
Thanks for your answer @Bruno_ST​.
The UART on Raspberry pi 4 is 3V3 and not 5V. I checked this with my scope.
‎2022-02-04 9:25 AM
Your code on the STM32 side can only read 1 byte. The 1bytes of data you read looked like part of a UTF-8 encoded character.
If you don't know how many bytes the incoming data will be, below is an example I randomly found on google. it will solve your problem.
http://www.bepat.de/2020/12/02/stm32f103c8-uart-with-dma-buffer-and-idle-detection/
‎2022-02-05 12:50 AM
@Muhammed G�ler​
What I wanted is to receive just 1 byte (0x01 or 0x00). Nevertheless, I get 240 but I can't see the link between 240 and 1 even with the UTF-8 encoding.
‎2022-02-07 12:17 AM
Sorry, you are right !! I mixed-up myself...
Bruno
‎2022-02-07 12:24 AM
I know its a dumb question but is your wiring OK?
Are you wiring your stm32's GND with your raspi GND¿
‎2022-02-07 2:13 AM
I already checked the connection : Tx_Raspberry -> Rx_STM32 and Rx_Raspberry ->Tx_STM32 and also same ground.
‎2022-02-07 3:38 AM
i find ftdi's usb-UART modules very usefull to debug this kind of scenarios.
**extra: i had some problems back in the day with the raspi's internal bluetooth trying to take over the uart i was using .....
