2025-01-12 6:09 PM - edited 2025-01-12 6:13 PM
HI
I'm trying to reduce the noise of a high RPM motor with the library below.
- STM32Cube function pack for acoustic echo cancellation
- https://www.st.com/en/embedded-software/fp-aud-aec1.html
The subject is to reduce the noise of a high RPM motor with a vacuum cleaner.
- Motor RPM is fixed
There is not much information about 'STM32Cube function pack for acoustic echo cancellation' yet.
So I am not sure if this is possible yet, so I am asking.
2025-02-12 5:04 AM
I am not sure to understand well your use case.
If you want to remove the noise emitted by a device, in every direction, we don’t have a solution.
If you want to capture audio from a microphone, close to a motor, it is feasible.
the package FP-AUD-AEC1 doesn’t contain the right algorithm (this one is echo cancellation, used to remove a loudspeaker output from the microphone input).
X-CUBE-AUDIO-KIT contains examples for noise reduction.
https://www.st.com/en/embedded-software/x-cube-audio-kit.html
