timer interrupt issue
  • December 15, 2023
  • 1 reply
  • 863 views
we are using the stm32f7508-dk board , we added  one function in while and timer 3 interrupt enabled  in that code .
when debugging the code continuously its going to  interrupt , the code in while function executing if i add break points. i f i remove the break points its miss behaving
1 reply
Find the bug and fix it.
If you add more details, you may get a more useful response here. We don't know what misbehaving means, or what the expected behavior is, or any other details. Consider limitations on interrupt frequency.
