TIM3 CH2 external counter configuration
Gergo Santha
Posted on April 10, 2018 at 14:55
Hi!
I want to use an external clock signal for timing. This clock signal is ~130 kHz. I want to count N pulses with a timer and I want an IRQ after N pulses. For this purpose I'd like to use TIM3 in external counter mode 1. The input pin is PC7 which is TIM3_CH2 in alternate function 2. I'm using the LL driver. So far I came up with this but it's not working no matter what value I write in to the ARR register. This code is based on several examples in CUBE_FW_L4 and other web sources. I know that there are lots of code out there but it seems that people are using different drivers like standard, HAL etc. I call timing_init_timing() function to configure the pins, timer etc. The function timing_set_ARR is used from a command terminal and I get zero calling timing_get_counter() function and the timcnt readout is always 1.
I already had my laps on reference manual but I really not get the concept as the driver is using confusing names which I couldn't found in the RM of the MCU. I'm missing some points probably so any help would be great.
void
timing_configure_input_pin
void
// Clock
  LL_AHB2_GRP1_EnableClock
LL_AHB2_GRP1_PERIPH_GPIOC
// TIM3 configuration on GPIO PC7, alternate function 2
  LL_GPIO_SetPinMode
GPIOC
LL_GPIO_PIN_7
LL_GPIO_MODE_ALTERNATE
  LL_GPIO_SetPinPull
GPIOC
LL_GPIO_PIN_7
LL_GPIO_PULL_DOWN
  LL_GPIO_SetPinSpeed
GPIOC
LL_GPIO_PIN_7
LL_GPIO_SPEED_FREQ_HIGH
  LL_GPIO_SetAFPin_0_7
GPIOC
LL_GPIO_PIN_7
LL_GPIO_AF_2
void
timing_configure_nvic
void
  NVIC_SetPriority
TIM3_IRQn
0
  NVIC_EnableIRQ
TIM3_IRQn
void
timing_configure_timer
void
// Clock
  LL_APB1_GRP1_EnableClock
LL_APB1_GRP1_PERIPH_TIM3
  LL_TIM_IC_SetFilter
TIM3
LL_TIM_CHANNEL_CH2
LL_TIM_IC_FILTER_FDIV1
  LL_TIM_IC_SetPrescaler
TIM3
LL_TIM_CHANNEL_CH2
LL_TIM_ICPSC_DIV8
  LL_TIM_IC_SetPolarity
TIM3
LL_TIM_CHANNEL_CH2
LL_TIM_IC_POLARITY_RISING
  LL_TIM_IC_SetActiveInput
TIM3
LL_TIM_CHANNEL_CH2
LL_TIM_ACTIVEINPUT_DIRECTTI
  LL_TIM_SetClockSource
TIM3
LL_TIM_CLOCKSOURCE_EXT_MODE1
  LL_TIM_CC_EnableChannel
TIM3
LL_TIM_CHANNEL_CH2
  LL_TIM_EnableIT_UPDATE
TIM3
  LL_TIM_GenerateEvent_UPDATE
TIM3
void
timing_set_ARR
uint16_t
val
  LL_TIM_SetAutoReload
TIM3
val
uint32_t
timing_get_counter
void
return
LL_TIM_GetCounter
TIM3
void
timing_init_timing
void
void
TIM3_IRQHandler
void
if
LL_TIM_IsActiveFlag_UPDATE
TIM3
1
// Clear the update interrupt flag
    LL_TIM_ClearFlag_UPDATE
TIM3
    board_toggle_NUCLEO_LED
    timcnt
Gergo Santha
Posted on April 11, 2018 at 12:18
Okay, I converted a code based on Std Periph library to direct register read/write and it is working now. I paste the code here. The input signal is ~130209 Hz connected to PC7 of STM32L476RG from SPIRIT1 XO, 25e6 MHz/192.
void timing_configure_input_pin(void) {
    /* Enable the peripheral clock of GPIOs */
    LL_AHB2_GRP1_EnableClock(LL_AHB2_GRP1_PERIPH_GPIOC);
  /* GPIO TIM3_CH2 configuration */
  LL_GPIO_SetPinMode(GPIOC, LL_GPIO_PIN_7, LL_GPIO_MODE_ALTERNATE);
  LL_GPIO_SetPinPull(GPIOC, LL_GPIO_PIN_7, LL_GPIO_PULL_DOWN);
  LL_GPIO_SetPinSpeed(GPIOC, LL_GPIO_PIN_7, LL_GPIO_SPEED_FREQ_HIGH);
  LL_GPIO_SetAFPin_0_7(GPIOC, LL_GPIO_PIN_7, LL_GPIO_AF_2);
void timing_configure_nvic(void) {
  NVIC_SetPriority(SPIRIT1_XO_OUT_TIMER_CC_IRQn, 0);
  NVIC_EnableIRQ(SPIRIT1_XO_OUT_TIMER_CC_IRQn);
void timing_ti2_config(void) {
  // Temporary variables
  uint16_t tmpccmr1 = 0, tmpccer = 0, tmp = 0;
  /* Disable the Channel 2: Reset the CC2E Bit */
  TIM3->CCER &= (uint16_t)~TIM_CCER_CC2E;
  tmpccmr1 = TIM3->CCMR1;
  tmpccer = TIM3->CCER;
  tmp = (uint16_t)(0x00 << 4); // TIM_ICPolarity_Rising = ((uint16_t)0x0000)
  /* Select the Input and set the filter */
  tmpccmr1 &= ((uint16_t)~TIM_CCMR1_CC2S) & ((uint16_t)~TIM_CCMR1_IC2F);
  tmpccmr1 |= (uint16_t)(0x00 << 12); // TIM_ICFilter:  must be a value between 0x00 and 0x0F.
  tmpccmr1 |= (uint16_t)(0x0002 << 8); //CC2S[1:0] 10: CC2 channel is configured as input, IC2 is mapped on TI1
  /* Select the Polarity and set the CC2E Bit */
  tmpccer &= (uint16_t)~(TIM_CCER_CC2P | TIM_CCER_CC2NP);
  tmpccer |=  (uint16_t)(tmp | (uint16_t)TIM_CCER_CC2E);
  /* Write to TIMx CCMR1 and CCER registers */
  TIM3->CCMR1 = tmpccmr1 ;
  TIM3->CCER = tmpccer;
void timing_select_input_trigger(void) {
  uint16_t tmpsmcr = 0;
  /* Get the TIM3 SMCR register value */
  tmpsmcr = TIM3->SMCR;
  /* Reset the TS Bits */
  tmpsmcr &= (uint16_t)~TIM_SMCR_TS;
  /* Set the Input Trigger source */
  tmpsmcr |= (uint16_t)0x0060; // TS[6:4] 110: Filtered Timer Input 2 (TI2FP2)
  /* Write to TIMx SMCR */
  TIM3->SMCR = tmpsmcr;
void timing_configure_timer(void) {
  SPIRIT1_XO_OUT_TIMER_CC_CLK_ENABLE();
  // CMS = b00 (counter counts up/down depending on DIR bit
  // DIR = b0 counter upcounter
  // CKD = b00
  TIM3->CR1 &=~(TIM_CR1_DIR | TIM_CR1_CMS | TIM_CR1_CKD);
  // Set ARR value (period)
  TIM3->ARR = 1;
  // Set prescaler
  TIM3->PSC = 1301; // The counter clock frequency CK_CNT is equal to f CK_PSC / (PSC[15:0] + 1)
  timing_ti2_config();
  timing_select_input_trigger();
  TIM3->SMCR |= (uint16_t)0x0007; // TIM_SlaveMode_External1 = ((uint16_t)0x0007)
  TIM3->DIER |=TIM_DIER_UIE;
  TIM3->CR1 |= TIM_CR1_CEN;
void timing_init_timing(void) {
    timing_configure_input_pin();
    timing_configure_nvic();
    timing_configure_timer();
void SPIRIT1_XO_OUT_TIMER_IRQ_HANDLER(void)
  if(LL_TIM_IsActiveFlag_UPDATE(SPIRIT1_XO_OUT_TIMER) == 1)
    /* Clear the update interrupt flag*/
    LL_TIM_ClearFlag_UPDATE(SPIRIT1_XO_OUT_TIMER);
    board_toggle_NUCLEO_LED();
    timcnt++;
5 REPLIES 5
henry.dick
Senior II
Posted on April 10, 2018 at 15:35
A few ways of doing it.
1. For a count up counter, load the counter with -N and use the overflow interrupt.
2. For count down counter, load the counter with initial value of N and overflow interrupt.
3. Set the compare match at N and use the cc interrupt.
4. Use a Pressler of 129, and load the counter with -1.
The possibility is simply endless.
Posted on April 10, 2018 at 15:42
dhenry,
thank you for your help. At the moment I'm not getting much change in my timcnt variable (and I read out zero when I call LL_TIM_GetCounter function), so I've a feeling that the signal is not routed into the timer correctly. I'm not sure that my code is correct either as I couldn't find a code example with the LL driver.
Posted on April 10, 2018 at 23:35
Does it count at all?
Read back and check/post the GPIO and TIM registers content.
Then why do you use the 'driver' at all?
Posted on April 11, 2018 at 01:07
I'm with JW on this. If you are not comfortable with LL, don't use it until you do get comfortable.
Gergo Santha
  // CKD = b00
  TIM3->ARR = 1;
  // Set prescaler
    timcnt++;
