2008-06-16 12:49 AM
TIM_OCMode
2011-05-17 03:37 AM
hi,
I am newbie trying with STM32 timer. Can any one explain or tell me where can i find information on the different between following timer mode? Table 476. TIM_OCMode definition TIM_OCMode_Timing: TIM Output Compare Timing mode. TIM_OCMode_Active: TIM Output Compare Active mode. TIM_OCMode_Inactive: TIM Output Compare Inactive mode. TIM_OCMode_Toggle: TIM Output Compare Toggle mode. TIM_OCMode_PWM1: TIM Pulse Width Modulation mode1. TIM_OCMode_PWM2: TIM Pulse Width Modulation mode2. Many Thanks :-D2011-05-17 03:37 AM
Hello h.s.low,
Here it is the forum for ST7 8 bit micro. For STM32 questions, please post your message in the appropriate forum called ARM Cortex-M3 STM32 (http://www.st.com/mcu/forumsid-23.html). Thank you for your understanding. Best regards, Seb
