TIM_OCMode? which one to use?
hs.low9
Posted on June 16, 2008 at 12:43
hs.low9
Posted on May 17, 2011 at 12:37
hi,
I am newbie trying with STM32 timer.
Can any one explain or tell me where can i find information on the different between following timer mode?
Table 476. TIM_OCMode definition
TIM_OCMode_Timing: TIM Output Compare Timing mode.
TIM_OCMode_Active: TIM Output Compare Active mode.
TIM_OCMode_Inactive: TIM Output Compare Inactive mode.
TIM_OCMode_Toggle: TIM Output Compare Toggle mode.
TIM_OCMode_PWM1: TIM Pulse Width Modulation mode1.
TIM_OCMode_PWM2: TIM Pulse Width Modulation mode2.
Many Thanks
hs.low9
