This can be realized with DAC and ADC in STM32F103?
‎2016-03-01 7:52 AM
Rapid
insight into
the datasheet
no problem
but
rather
ask:
‎2016-03-01 8:57 AM
I looks plausible, just, for a 72 MHz F1, there are likely better choices to get a more stable 1MSps
‎2016-03-01 11:34 AM
I thought about
STM32F103RD on 56MHz, Rdue to 64kB RAM and 56MHz
because
max ADC fadc is 14MHz.- Mark as New
‎2016-03-01 11:18 PM
In theory, yes. However, ST's DAC implementation has settling rates of about 4 .. 5 us (check the datasheet), you will hit a bandwidth limit here.
‎2016-03-02 1:43 AM
The devil is in the details.
In datasheet say t setting =3-4us Settling time (full scale: for a 10-bit input code transition between the lowest and the highest input codes when DAC_OUT reaches final value ±1LSB.Expressed in angles, Setting from 0 to 1/2PI and for load R=5kOhm C=50pF. For my sinus wave have transition 250 point to 1/2PiIf use external amplifier for example AD8628 total setting time =Sqrt(tsDAC^2 +tsAMP^2)= Sqrt (4^2+3.3^2)=5.2us max and 4.5us Typ, for code transition from 0 to 4096, 5.2/4096 = 1.27ns/LSB. Biggest change in my sinus wave is 13LSB 16.5ns.- Mark as New
‎2016-03-02 3:27 AM
Yes, you need to check it for your own application. Just wanted point out the fact that you can feed the DAC DR register much faster than the output can follow. A 3db-bandwidth of 1.0 MHz (or 500kHz) is unrealistic.
