SWD Debug problem
dizarker
Posted on December 15, 2014 at 06:53
Good day,
I have problem with debugging through swd: programming is done, debug process started, but after few seconds drop error message -- Cannot connect to target.
And no variables change in watch window.
(Use Keil v5.12)
Posted on December 15, 2014 at 07:56
Are you putting the core into a low power or sleep mode, which would turn off power to the core/interface? WFI loop?
Are you reconfiguring pins required for the interface to function?
