2014-12-14 9:53 PM
Good day,
I have problem with debugging through swd: programming is done, debug process started, but after few seconds drop error message -- Cannot connect to target.And no variables change in watch window.(Use Keil v5.12)2014-12-14 10:56 PM
Are you putting the core into a low power or sleep mode, which would turn off power to the core/interface? WFI loop?
Are you reconfiguring pins required for the interface to function?
