2018-02-13 3:36 AM
Hi , I want sample code for STP16CPC26XTR with interface STM32F103. Then how to connect more one
STP16CPC26XTR with STM32F103. Please help anyone.
Thanks & regards,
Murugan K
#stp16cpc26xtr #stm32f1032018-02-13 4:42 AM
Hi, it looks like a job for SPI... in 16bit mode.
you don't need to use the serial out, it is for cascading.to the next Driver.
you will need to use 2 output GPIOs to run the LE and /OE pins
make sure your Rext cannot go to Zero ohms, something is likely to get upset.
usually the very minimum R in series with a pot.
2018-02-13 7:29 AM
Have you looked at:
EDIT
And AN3981
: LED array drivers - found on the Product Page:
