Apr 26, 2024 7:13 AM UTC
Store values in internal flash
Can variable values be stored in some fixed addresses of internal flash and retrieved from them after reset?
is there any example for same.
Andrew Neil
Andrew NeilBest answer
Apr 26, 2024 9:24 AM UTC
@Uwe Bonnes wrote:
You can write to erased memory cells.
@GauravK for more on this, see:
https://community.st.com/t5/stm32-mcus-products/flash-write-versus-erase-cycles/m-p/665631/highlight/true#M241948
and follow the link.
Uwe Bonnes
Chief
Apr 26, 2024 9:07 AM UTC
You can write to erased memory cells. This must happen in chunks, e.g. 256 bits on H7 and down to single bytes on some older families. If the retrieved value needs to be reporgrammed later, look for EPROM emulation.
Andrew Neil
GauravKAuthor
Apr 30, 2024 9:09 AM UTC
I will be checking and get back if needed
Andrew Neil
Apr 26, 2024 9:16 AM UTC
Akuma.6
Jul 18, 2024 3:20 AM UTC
I am working on STM32G0 series and trying to save the records (120bytes each record) into internal mcu flash memory location and when it required will read the read the stored records and do our operations.
Please let us know the logic.
Kumar
Andrew Neil
Jul 18, 2024 9:19 AM UTC
See the links posted earlier!
Some more info here - including links to some other implementations:
https://community.st.com/t5/stm32-mcus-embedded-software/eeprom-emulation-virtual-addresses/m-p/675788
