April 26, 2024
Store values in internal flash
  • April 26, 2024
  • 6 replies
  • 2058 views
Can variable values be stored in some fixed addresses of internal flash and retrieved from them after reset?
is there any example for same.
Best answer by Andrew Neil
@Uwe Bonnes wrote:
You can write to erased memory cells.
@GauravK for more on this, see:
https://community.st.com/t5/stm32-mcus-products/flash-write-versus-erase-cycles/m-p/665631/highlight/true#M241948
and follow the link.
Uwe Bonnes
Chief
April 26, 2024
You can write to erased memory cells. This must happen in chunks, e.g. 256 bits on H7 and down to single bytes on some older families. If the retrieved value needs to be reporgrammed later, look for EPROM emulation.
Andrew Neil
Andrew NeilBest answer
GauravKAuthor
April 30, 2024
I will be checking and get back if needed
Andrew Neil
Akuma.6
I am working on STM32G0 series and trying to save the records (120bytes each record) into internal mcu flash memory location and when it required will read the read the stored records and do our operations.
Please let us know the logic.
Kumar
Andrew Neil
See the links posted earlier!
Some more info here - including links to some other implementations:
https://community.st.com/t5/stm32-mcus-embedded-software/eeprom-emulation-virtual-addresses/m-p/675788
