STM32U575VGT HAL_FLASHEx_Erase() not working (page is not erased)
Adriano Melis
Hello all,
this code snippet is not working: the page is not erased, although the HAL does not report errors.
No RTOS is running.
if (HAL_ICACHE_Disable() != HAL_OK) {
Error_Handler();
status = HAL_FLASH_Unlock();
if (status != HAL_OK) {
Error_Handler();
erase_init_struct.TypeErase = FLASH_TYPEERASE_PAGES;
erase_init_struct.Banks = FLASH_BANK_1;
erase_init_struct.Page = 127;
erase_init_struct.NbPages = 1;
status = HAL_FLASHEx_Erase(&erase_init_struct, &page_error);
Error_Handler();
Any suggestion?
Adriano Melis
Hello all,
I found the source of the problem: the DUALBANK bit in FLASH_OPTR was set to 1.
On this device this arranges the FLASH page access in two banks of 64 pages each.
12 REPLIES 12
How are you verifying the page is not erased? What tool and memory addresses are you looking at?
I am monitoring the page content using the Memory renderer of STM32Cube Ide, there are values different from the erased value 0xFFFFFFFF
Adriano Melis
Sarra.S
Hello @Adriano Melis
The page 127 in bank1 is in 0x080F E000 - 0x080F FFFF
the screenshot you showed, does not show page 127
Adriano Melis
my bad. this is an actual screenshot: Flash erase has been executed, FLASH content is unchanged.
(status value is HAL_OK)
Sarra.S
I tried to reproduce your issue using the FLASH_EraseProgram example in STM32U5CubeFW, however, page 127 was erased successfully and I couldn't reproduce it
Maybe share a minor project to reproduce it on my side.
hello, these are additional info:
  • the MCU is STM32U575VGT6 on a proprietary board clocked at 100 MHz: are there known problems on this particular device? The same code is OK on the Nucleo STM32U575ZI-Q
  • FLASH erase on a single page works fine from Cube Programmer
  • when the page is pre-erased with Cube Programmer writing data is successful
I suppose you're setting Flash latency to 3WS?
