STM32L476 Changing VRef for ADC precision
‎2025-03-19 12:02 PM
Hi I want to sample low voltage signals with STM32L476 so I figured it would be a good option to reduce reference voltage and I found this part in the MCU datasheet:
Now I am using ADC in dual mode and sampling 8 bit so it is not too precise for low voltages.
In ADC1 settings, there is a checkbox:
Is it enough to set it to shift Vref from 3.3 to 2.048 or how should I set my reference voltage to 2.048?
Also If I decide to use an external Vref can I just connect lets say 1V to Vref+ for MCU to change Vref for ADC to 1V from 3.3V.
- Labels:
STM32L4 series
‎2025-03-19 12:20 PM
VREFBUF is enabled in the SYS tab. VREFINT is and ADC channel and is not relevant here.
No, there are limits on VREF+, see datasheet.
‎2025-03-19 12:35 PM
Thank you for the quick reply. I checked the system thinking it might be under there but I cannot see VREF Buffer option.
‎2025-03-19 2:21 PM - edited ‎2025-03-19 2:21 PM
Include your full chip part number and your IOC file if you can.
‎2025-03-19 6:03 PM
If the VDDA pin is tied to the VREF+ pin as it is on the nucleo board, the VREFBUF is unable to be used.
‎2025-03-20 3:35 AM
I am using Nucleo-L476RG. I believe VDDA pin can be tied to the VREF+ pin so that can be the problem because I created the project adding the board.
