stm32L452CEU6 usb doesnt work with Samsung GalaxyTab A8
‎2024-04-30 10:13 AM
I have a board design based on stm32L452 , USB gets recognized on a windows PC and I can talk to the device over any software like putty and a Test software sees the com port and can to the device. However in Android (Iam using samsung GalaxyTab A8), usb is not even recognized. The Tab support OTG mode and I did change default USB mode in the tab (Tried all the combo, file transfer, teethering, media etc). Nothing helps. Any advice is greatly appreciated
STM32L4 Series
‎2024-05-06 7:13 AM
We will check that.
How we can enable debug message from USB lib and where we can see these messages?
‎2024-05-06 7:44 AM
You need SWO /swd , then if enable the debug msg in Cube setup, see it.
+ in Cube set debug ->
(search/read here in forum, how to do - i wrote it > 2 times. )
‎2024-05-07 5:41 AM
I have followed the previous recommendation and enabled debug message in cube ide setup and enabled SWO in debug configuration. But, when I tried to print a sample string "Hello" I got some junk values. Could you please confirm if there is any other configuration?
‎2024-05-07 5:41 AM
Just few updates
1) Tried USB mass storage, it came up on windows and mac but not working in Android
2) CDC driver same behavior , works in windows and mac but not in android
3) Use the external clk so crs_sync is no longer used
4) USB D- and D+ are correct. Its just a connector naming issue ( otherwise as u said it wouldnt work in windows or mac)
In all combinations, so far it works in windows/mac but not in android. We are basically stuck with this issue.
Currently looking at pulling log information via SWD, even though message comes out, its all scrambled , why would it be? clk issue ?
‎2024-05-07 5:45 AM
for clarity, we are not setup for 48M for USB from HSE/PLL.
What else we can try?
1) Try another android tab ? ( we are using galaxy A8 and A2, same behaviour)
2) Heard there is an Android sim software that can run on PC? may be try that and see?
Any other suggestions?
‎2024-05-07 7:05 AM
SWO output looks like wrong speed setting.
Did you set the real cpu core clk frequency in debug ?
eh ? not 48M or just using HSI ?
‎2024-05-07 7:14 AM
Core frequency we set to 80MHz, which is the frequency the controller running
‎2024-05-07 7:35 AM
for clarity, we are setup for 48M for USB from HSE/PLL. (sorry about typo, it is 48M for USB from HSE/PLL)
‎2024-05-07 7:51 AM
Ok, and also correct clock in debug -> swo settings ->
(here on H563 at 250M )
‎2024-05-07 8:41 AM
Below are the settings we done
