STM32L151 Signals generator with time shift/delay
Options
‎2013-08-28 7:10 AM
Posted on August 28, 2013 at 16:10
I've succeeded to generate the first and the second signal, by doing the follow manipulation.TIM4 (PWM Mode) generate 8MHz at D.C 50%, and set as master trigger to TIM3 so they can be synced together. TIM3 (PWM Mode) set to slave and runs at 4MHz at D.C 25% in order to generate the second signal (TIM3-1). but my problem is to generate the third signal (TIM3-2) that need to run on even cycles....how can I generate the third signal with shifting?many thanks for the help. #tim3 #stm32 #timers #pwm #tim4
I'm trying to generate 3 signal using TIM3&TIM4.the first signal run at 8MHz, DutyCycle 50%, the second signal should run every odd cycles of the first signal and the third should run every even cycles of the first signal. (see the image below)
Labels:
- Labels:
TIM
Options
‎2013-08-28 1:13 PM
Posted on August 28, 2013 at 22:13
I don't see an easy way to do this with two channels on the same timer. Two separate timers I can see just controlling the relative phase.
Options
‎2013-09-01 1:41 AM
Posted on September 01, 2013 at 10:41
thanks for the replay,
If I simplified the use, and work with 3 different timers, TIM2 (for signal one) TIM3 (for signal two) TIM4 (for signal three), TIM2 and TIM3 implementations are easy. but still how can I implement the phase on the third signals using TIM4?Options
‎2013-09-01 6:37 AM
Posted on September 01, 2013 at 15:37
Slew TIM4->CNT wrt TIM3->CNT
