STM32H745I-Disco PWM Input Frequency Not detecting
CChri.5
Hi, I am trying to detect a 3v PWM frequency with my STM32, I have my live expresions setup for my variables, but the values do not budge from 0. Im sure it is something up with my code. Any help would be appreciated cheers.
6 REPLIES 6
CChri.5
static void MX_TIM1_Init(void);
/* USER CODE BEGIN PFP */
/* USER CODE END PFP */
/* Private user code ---------------------------------------------------------*/
/* USER CODE BEGIN 0 */
uint32_t ICValue = 0;
uint32_t Frequency = 0;
float Duty = 0;
void HAL_TIM_IC_CaptureCallback(TIM_HandleTypeDef *htim)
	if (htim->Channel == HAL_TIM_ACTIVE_CHANNEL_1)  // If the interrupt is triggered by channel 1
		// Read the IC value
		ICValue = HAL_TIM_ReadCapturedValue(htim, TIM_CHANNEL_1);
		if (ICValue != 0)
			// calculate the Duty Cycle
			Duty = (HAL_TIM_ReadCapturedValue(htim, TIM_CHANNEL_2) *100)/ICValue;
			Frequency = 36000000/ICValue;
/* USER CODE END 0 */
CChri.5
int main(void)
  /* USER CODE BEGIN 1 */
	HAL_TIM_IC_Start_IT(&htim1, TIM_CHANNEL_1);  // channel 1 main
	HAL_TIM_IC_Start(&htim1,  TIM_CHANNEL_2); // channel 2 indirect
  /* USER CODE END 1 */
CChri.5
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
  RCC_OscInitStruct.HSEState = RCC_HSE_ON;
  RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
  RCC_OscInitStruct.PLL.PLLM = 5;
  RCC_OscInitStruct.PLL.PLLN = 72;
  RCC_OscInitStruct.PLL.PLLP = 2;
  RCC_OscInitStruct.PLL.PLLQ = 4;
  RCC_OscInitStruct.PLL.PLLR = 4;
  RCC_OscInitStruct.PLL.PLLRGE = RCC_PLL1VCIRANGE_2;
  RCC_OscInitStruct.PLL.PLLVCOSEL = RCC_PLL1VCOWIDE;
  RCC_OscInitStruct.PLL.PLLFRACN = 0;
    Error_Handler();
CChri.5
The input signal is connect to my PA8 terminal of my STM32
lbthomsen
Did you enable the Global interrupt of the timer you use for the capture?
I've got a working example described here: https://stm32world.com/wiki/STM32_Timer_PWM_Input_Capture
Ah, I think thats where I have gone wrong. I'll sort that out, if that doesn't work i'll give your example a trial. Cheers!
