STM32H7 GPIO TOGLE MAX FREQUENCY
‎2018-05-07 5:08 AM
With STM32F765 and MDK-ARM compiler ( O3 and compile for SPEED I was able to achieve 108Mhz on output pin, performing while loop ( just main() and all interrupt disabled ) .
Now with STM32H743 with same compiler and same source maximum frequency is 16.7MHz , with PLL configured to have 400MHz clock ( tested on RCC_MCO2 output pin )
Anyone know why ?
‎2018-05-17 6:38 AM
Hi
Frigerio.Danilo
‌,First, we may ask about the relevance of toggling a GPIO with CPU at maximum clock (as stated by Avatar)?
For some use-cases, you may use a timer ...
Back to the explanation of the discrepancy between results with STM32F7 and the ones with STM32H7: the main reason is that both families don't share the same architecture:
- STM32F7 has one bus matrix and both the Core and and GPIO are connected to that same bus matrix
- STM32H7 has three domains.Cortex-M7 is connected to AXI bus matrix while the GPIO is connected to another AHB bus matrix. Then, a latency is introduced because of bridges connecting these bus matrices.
You may refer to 'System Architecture' section in the reference manuals of both products for more details.
-Amel
‎2018-05-07 7:42 AM
Default clock, bus speed, gpio drive, compiler optimization, software access approach, coding, ....
‎2018-05-07 9:57 AM
GPIO glitch filter.
WTH is the relevance of toggling a pin with 100% core load ?
‎2018-05-17 6:38 AM
Hi
Frigerio.Danilo
-Amel
‎2018-05-17 9:00 AM
Dear Amel
What you said is about what I imagined, really I don't need to toggle
pin at this speed, this was just to compare M7 and H7.
I will compare it in a real way, comparing my fw now running on
STM32F765 ( high speed camera scanning )
Thanks and regards
Danilo Frigerio
Il 17/05/2018 15:38, Amel N ha scritto:
<,https://community.st.com/?et=watches.email.thread>,
Re: STM32H7 GPIO TOGLE MAX FREQUENCY
reply from Amel N
/STM32 MCUs Forum/ - View the full discussion
<,https://community.st.com/0D70X000006Sm8qSAC
