STM32f769I- discovery board interface with mcp9600 using I2C
Denial
hello everyone, i am using STM32f769I- discovery board i want to interface mcp9600 temperature sensor using I2C, can i get any example code .It will be very useful thank you
3 REPLIES 3
kgbfizz
Hello Denial,
I am currently experiencing the same problem, did you ever get the stm to interface properly with the mcp9600? If so could you please assist me?
Many thanks,
kgbfizz
Perhaps you could leverage a review of the data sheet, and example drivers for assorted platforms.
https://github.com/adafruit/Adafruit_MCP9600/blob/master/Adafruit_MCP9600.cpp
https://github.com/topics/mcp9600
The STM32F769I DISCO has I2C readily exposed on the Arduino Headers
You need to elaborate more about your issue.
What's is the problem you're facing? Did you check SDA and SCL lines with an oscilloscope? The HW (the pull-up resistors etc ..)?
And what about the sensor I2C address? configured correctly?
PS:
1 - This is NOT an online support (https://ols.st.com) but a collaborative space.
2 - Please be polite in your reply. Otherwise, it will be reported as inappropriate and you will be permanently blacklisted from my help.
