2017-02-15 10:28 PM - last edited on 2024-10-23 2:10 AM by Andrew Neil
Posted on February 16, 2017 at 07:28
1>> We understand that
STM32F769 DCMI(Digital Camera interface) is able to process YCbCr 4:2:2 and RGB 565.
We could see sample camera program in STM32Cube with video input as RGB 565 format to DCMI module and displaying on LCD with RGB888 format.
But we are not able to find sample program with YCbCr 4:2:2.
Can anyone please share sample program/related document to test YCbCr 4:2:2 input to the DCM and displaying on LCD.
2.
As we know that the IDE/work bench like IAR and Keil has license concerns,
we would like to know the suggestion from ST regarding the Free workbench/IDE available for STM32Cube code compilation for STM32F769I-EVAL board.
Thanks,
Utpal
2017-02-21 6:53 AM
Hi
kumar.utpal
,Maybe you have the Jumper in JP10 !
So, remove the jumper JP10,then keep me updated on your results.
Imen
2017-02-16 8:24 AM
1- Maybe you can find several discussions in the STM32 forum that can help you, as this one with example for STM32F4
https://community.st.com/0D50X00009XkbA7SAJ
2- You may refer to these manuals
or Getting started with STM32 software development toolswhich provides a step by step guideline on how to build and debug an application using some toolchains as the free IDE
by AC6 based on Eclipse.Hope this helps you.
Imen
2017-02-21 12:56 AM
Hi All,
I am facing issues mentioned below too.
Currently we are testing the sample camera application(DCMI capture example) given in the STM32Cube on STM32769i-Eval board.
Application Path:STM32Cube_FW_F7_V1.6.0\Projects\STM32F769I_EVAL\Examples\DCMI\DCMI_CaptureMode
We found the camera captured image is not proper and attached screen shot for reference.
We have checked another Camera application available in STM32Cube (DCMI snapshot mode and Camera to USBDisk ) and observed the same behavior.Please let us know any specific configuration to be done (in SW/HW) to get proper image.
2017-02-21 6:53 AM
Hi
kumar.utpal
Imen
2017-03-10 5:32 AM
Hey ,
Thank your so much .
Its working.:)
2024-10-23 1:54 AM
How do you convert YCbCr 4:2:2 input to RGB888 format in order to display it on LCD?
Do you handle the conversion in software?
Thank you
