STM32F746G DISCO
AD�?b
How to remember data after power off in STM32F746G DISCO?
Andrzej
You will also find samples for your board in your local repository, which is downloaded for tools like STM32CubeMX or STM32CubeIDE.
You could e.g. take a look at:
  • EEPROM_Emulation -> Repository\STM32Cube_FW_F7_V_._._\Projects\STM32746G-Discovery\Applications\EEPROM
  • FLASH_EraseProgram -> Repository\STM32Cube_FW_F7_V_._._\Projects\STM32746G-Discovery\Examples\FLASH\FLASH_EraseProgram
The latter not only shows how to erase Flash blocks, but also writes some data into these blocks beforehand, e.g. 0x12345678.
We hope you enjoy writing and reading the Flash.
/Peter
4 REPLIES 4
Peter BENSCH
Unfortunately, the VBAT pin on the 32F746GDISCOVERY is permanently connected to VDD (no resistor/bridge/etc inbetween), so a battery/supercap cannot be connected.The only way here is to store data in Flash or e.g. on an external EEPROM you can connect to the 32F746GDISCOVERY.
Good luck!
/Peter
Any example for flash? How to do it?
Andrzej
/Peter
Thanks!
greetings
I wish you a peaceful Christmas.
Andrzej
