STM32F4DISCOVERY VBAT pin
‎2014-03-31 8:10 AM
Hi all,
I want to use RTC from STM32F4DISCOVERY and have a doubt about VBAT pin that is connected to VDD through R26 0Ohm, this are saying that I need to take off R26 to plug a vbat battery, but if I take off the R26 a jerry-rig is needed to connect battery. So I ask, is it true, that I need to take off R26 and make a jerry-rig to plug vbat battery. or I can plug the vbat battery in VDD with a diode, because the cpu turn-off everything other peripherals, except VBAT domain , when VDD fall down below some value prefixed? Best regards, Paulo #rtc-vbat- Labels:
RTC
‎2014-04-01 5:06 AM
Is it a fool question?? I think that a lot of guys are using RTC in this kit. Nor Clive put an answer. Best regards. Paulo- Mark as New
‎2014-04-01 5:25 AM
For the purpose of running the RTC (and/or the battery-backup SRAM), yes. The F4 DISCOVERY kit is not well prepared for connecting a battery. > or I can plug the vbat battery in VDD with a diode, because the cpu turn-off everything other peripherals, except VBAT domain , when VDD fall down below some value prefixed? That is possible, but it would be a different setup, keeping the whole F4 under power, relying on it to power down its peripherals and go to some of the power-saving modes (and resulting in higher consumption than in the previous case). On the DISCOVERY board, however, the other on-board ICs would remain powered by the battery, too. JW- Mark as New
‎2014-04-01 7:30 AM
Thank you so much for your answer.
\pdsilva- Mark as New
‎2014-04-01 8:13 AM
Perhaps the topic just didn't really interest me, or was framed awkwardly? Forum etiquette normally dictates if you don't have anything to add, don't post. And I didn't. I'm not sure removing or soldering parts on a cheap dev board represents ''jerry-rigging'', you're provided with a schematic for the express purpose of reviewing how the circuit works, and what you might be able to change on it. There is a lot of junk on the STM32F4-DISCO, the STM32L-DISCO might be a better choice, it has a provision for a battery, and has an LSE crystal mounted.Up vote any posts that you find helpful, it shows what's working..
‎2014-04-01 11:38 PM
Well, I wouldn't call the missing provisions for battery connection ''junk'', but you probably had also other things in mind - could you please comment? Thanks, Jan- Mark as New
‎2014-04-02 4:47 PM
Thank you for the advice, but I am a simple developer, and the customer want use this board, it is cheap and easy to buy.
thank you.
