2018-06-27 07:17 AM
Dear Community,
I’ve just installed the STM32F4cube from SetupSTM32CubeMX-4.26.0.exe but I cannot find the “
Hundreds of examples for easy understanding
� mentioned onhttps://www.st.com/en/embedded-software/stm32cubef4.html
or in AN4739.Unfortunately the installer hasn’t installed a folder having a similar name
like STM32Cube_FW_F4_VX.Y.Z\Projects\. .I would be very glad if someone could give a hint how to also instal those examples.
2018-06-27 08:12 AM
Go into the settings from CubeMX and look where you put the repository
E:\CT\STM32Cube\Repository\STM32Cube_FW_F4_V1.0\Projects\STM32F4-Discovery\Applications\FatFs\FatFs_USBDisk
This is Help -> Updater Settings
If you haven't installed the F4 packages, install those
2018-06-27 08:12 AM
2018-06-27 03:11 PM
Dear Clive,
the repository folder mentioned in your post is there but without any software in it. I’ve followed your hint to also download the F4cube “en.stm32cubef4.zip� and viola it contained all the examples I was searching for. Thank you very much for your help.
