stm32f429 discovery dfu problem
Options
‎2016-04-21 3:19 AM
Posted on April 21, 2016 at 12:19
I want to use bootloader from usb with stm32f429 discovery board. I have pull down the BOOT0 pin and pull up the BOOT1(PB2) pin. I have connected the boards to copmuter from usb connectors (from mini and micro usb) but i can not see the board as ''stm device in dfu mode'' in device manager. what can the solution be ?
Options
‎2016-04-21 4:20 AM
Posted on April 21, 2016 at 13:20
I don't believe the ROM supports DFU vis the USB_HS interface.
Options
‎2016-04-21 4:30 AM
Posted on April 21, 2016 at 13:30
why not? do you think that it is not possible with stm32f429 mcu or with discovery board?
