STM32F415RGT6 power scheme
zexx86
Posted on December 25, 2014 at 22:10
I am engineering new PCB. It is little bit unclear from datasheet so I would like to know if my power supply scheme is correct, especially decoupling capacitors.
Thank you very much!
#stm32-f4-power-supply-scheme
3 REPLIES 3
Posted on December 26, 2014 at 00:45
Definitely don't want to be tying NRST to the 3V3 supply.
zexx86
Posted on December 26, 2014 at 11:30
Thank you, so I can leave it unconnected?
Also do I need to connect VDDA, VSSA in case I don't plan to use Analog peripherals?
jpeacock
Posted on December 26, 2014 at 18:05
VDDA also powers the PLL clock multiplier, so it still has to be present even if you don't use the ADC.  I always run a ferrite bead between it and VDD, a choke for high frequency switching noise.
  Jack Peacock
