STM32f407G-DISC1 Technical Documents
‎2019-03-18 11:37 PM
Hi, i'm currently working with the MB997D version of the mentioned Development Kit on the caption. My main goal is working with the lis3dsh sensor on this board and then apply it to my own board, i've tried and accomplished the work with that sensor, but since there are no documents online for the mentioned version of that DK i couldn't apply it on my own PCB, cause current version of the mentioned DK contains some other lisXXX sensor with whole different pinouts.
So i want to know if there is any possible way for me to find technical documents for MB997D version.
Thanks in Advance
‎2019-03-19 3:51 AM
https://www.st.com/en/evaluation-tools/stm32f4discovery.html
UM1472 deals with the D revision of the board. On page 26, there's a yellow box with a list of changes for each revision; and among other things it says "Replace LIS302DL by LIS3DSH (U5)" for rev.C.
‎2019-03-19 5:29 AM
DiSC1 means it has an uprated F103 implementing the ST-LINK V2-1 functionality, but otherwise equivalent to the same revision DISCO ​
