2015-07-31 4:38 AM
As written in Ref.Man.
DMA stream x FIFO control register (DMA_SxFCR) (x = 0..7)
Address offset: 0x24 + 0x24 � stream number
Reset value: 0x0000 0021 It is true only for DMA1 streams, but for DMA2 reset value is 0x0. #dma #error
2015-08-03 9:02 AM
Hi kyb,
It seems that DMA1 clock is enabled in your case. If you enable DMA2 clock, you will see that reset value for DMA_SxFCR is 0x00000021.-Mayla-To give better visibility on the answered topics, please click on Accept as Solution on the reply which solved your issue or answered your question.
