Stm32f405rgt6 custom board not detected on stm32programmer,]
ArnavTakle
hey, I'm developing a custom stm32f405rgt6 board. I'm using stlink for uploading code. I'm comparitively new to stm as i've only worked with blue pill. I get "Error: No STM32 target found! If your product embeds Debug Authentication, please perform a discovery using Debug Authentication" this issue whenever i try to connect with stlink. i was not able to connect even once. I'm attaching the schematics below. I'm getting please help me solve the issue.
10 REPLIES 10
BarryWhit
Senior III
(your clone has no working reset for stm32, usually.)
Usually they do have one. And even without reset, the CubeProgrammer would still be able to connect, it would only be unable to reset after programming. So I don't think reset is the issue in this case.
- If a post has answered your question, please acknowledge the help you received by clicking "Accept as Solution".
- Once you've solved your issue, please consider posting a summary of any additional details you've learned. Your new knowledge may help others in the future.
