2023-09-22 11:28 PM
Hi All,
I wanted to move from STM32F401 to a ECC enabled MCU and came across the STM32U575/585 series. Is it possible to in place use the QFN48 package for stm32u575 in place of stm32f401?. The pinouts/ports/power pins all look to be the same. are there any red flags?
Please help with your expert advice!
Nilav
2023-09-22 11:59 PM
Hello @Nilav
To verify if they are compatible or not, you can use the STM32 CubeMX and follow those steps:
Then you can find all MCUs compatible with yours.
Best regards.
II
2023-09-22 11:59 PM
Hello @Nilav
Best regards.
II
2023-10-03 12:11 AM - edited 2023-10-03 12:11 AM
Thanks @Issamos . This helps. Just as a note. The pinout for stm32u575 and stm32f401 look to be the same and I'm checking if it works in place for my use case.. I will keep you posted.
