stm32f4 Timer
puneethj
Posted on November 10, 2015 at 17:34
Hello every one! How can i check if the timer is already running.. which flag to use I am trying this
if (TIM2 -> CR1 == TIM_CR1_CEN)
// turn led on blue
else
// turn led red on
but it does not work, please help me
#!stm32f4-disco #discovery #stm32f4 #timers
6 REPLIES 6
Posted on November 10, 2015 at 18:56
I'd presume it's looking for a bit level mask, not a comparison.
puneethj
Posted on November 10, 2015 at 19:11
I dont know, but my task is to check if the timer is enabled or disabled. Please tell me how can i do that
Posted on November 10, 2015 at 19:17
It's a bit, mask it and check if it's zero or not
if (TIM2->CR1 & TIM_CR1_CEN) // test the enable BIT
// turn led on blue
else
// turn led red on
ftiti
Posted on November 10, 2015 at 19:21
I have a solution proposal:
You can set an Update event by Software juste before enabling the timer ( timer when enabled it will generate an UEV )
  /* Set th UG bit to enable UEV */
  TIM1->EGR |= TIM_EGR_UG;
Then, you should manage by reading the UIF (update interrupt flag)  and cheking if it's set :
if ( (TIM2 -> SR & TIM_SR_UIF) != RESET )
// turn led on blue
else
// turn led red on
Good luck
puneethj
Posted on November 10, 2015 at 19:28
The problem with Update interrupt flag is it is always triggered even when the timer is not started.
ftiti
Posted on November 11, 2015 at 13:06
Yes, I see. Since UDIS and URS bit in TIM_CR1 are reset by defaut, by enabling the timer an UEV is automatically generated and thus the UIF bit is set .
So it beacomes more easy for your case and you can directly check if the timer is enabled or not through the UIF bit status:
// turn led on blue
else
// turn led red on
