STM32F4 - SDRAM - Byte enable
Options
2015-07-27 1:54 AM
Posted on July 27, 2015 at 10:54
i use a STM32F439 controller with 32Mbyte external SDRAM. I would like to configure some settings with STCube. There is a tab FMC with a sub-tab SDRAM1. When i select Data: 32 bits i can choose either Byte enable : disable or Byte enable : 32-Bit byte enable. Do you know if i should enable it ? For what exactly is it ?
0 REPLIES 0
