stm32F10x MSC with SPI Flash (W25Q256) problem
‎2025-01-21 1:23 AM - edited ‎2025-01-21 1:56 AM
I am trying make a USB device MSC.
It works fine with SD card, but I want both SD card and flash.( I set max_lun to 1.)
I have wrote the SPI_Flash_Write and SPI_Flash_Read that can be called by MAL_Write and MAL_Read.
It seems work fine cause I can format the flash disk on my computer and put files into the disk.
However, everytime I turn off my board and turn on it, it ask me to format the disk again and again.
I have searched many solutions. Someone said that I should use FATFS f_mkfs to format first.
I tried but not worked , is that true or any other problem I missed ?
thonsha
STM32F1 Series
‎2025-01-23 9:21 AM
Hi @thonsha
Would you provide some code snippets for these functions " SPI_Flash_Write and SPI_Flash_Read that can be called by MAL_Write and MAL_Read" .
I suggest you as a first step to isolate the problem and start with an example FATFS with micro SD card. Then we can move and use it as MSC Device.
‎2025-01-23 9:44 AM
Seems a bit subjective, given it's not actually retaining content. The caching on the host will hide a lot of ills.
Perhaps use 4KB sectors on the FLASH, and test the read returns the same data that was written. Have a big enough sector buffer, and MAX_SS is adequate.
You should only need to format the content once, either from the Host or via f_mkfs()
‎2025-02-02 8:37 PM - edited ‎2025-02-02 11:34 PM
Sorry for the late response. Just come back from the long vacation. :)
4KB sectors on the FLASH might be the key problem.
I can only format the FLASH with 512 byte sector, maybe it's why FLASH don't retain content.
I failed to format when using 4KB sector.
I guess something wrong with Write_Memory( ) function in memory.c because it support SD card with 512 byte sector.
I have no idea how to fix it . Is there any good suggestion ?
Thanks.
