2015-06-18 01:14 PM
2015-06-22 02:44 AM
Hi Eirik,
You can set the configuration you are expecting based on STM32CubeMX tool and generate the code allowing you to choose the timer as trigger for the ADC.Then you will have to add the calls for data processing functions.-Mayla-To give better visibility on the answered topics, please click on Accept as Solution on the reply which solved your issue or answered your question.
