STM32F103C8T6 Program not working and USB not recognized
‎2025-01-28 4:24 AM - last edited on ‎2025-01-28 5:09 AM by Andrew Neil
I found this schematic and layout with a stm32f103c8t6. I ordered it and wanted to programm it.
With stm32cubeprogrammer I detect the stm32 no problem via ST-LINK.
Same with stm32cubeide I can download successfully the code.
But now the problem is that eventhough the code is downloaded successfully the simple program to blink a pin to which I attach a diode is not working and I don’t see why.
I also want to be able to send data from my computer to the STM32 with USB but after downloading the code with "usb_device.h" and MX_USB_DEVICE_Init();, deconnecting ST-LINK and connecting with USB the STM32 is not recognized by the computer.
Any idea of what I could look for or ressources ?
If you see any problem in the design please tell me.
Jean
Bootloader
STM32F1 Series
USB
‎2025-01-28 4:42 AM
Blue Pill and other coloured ‘pills’ are not a product of STMicroelectronics and use counterfeit STM32F103, especially for the Blue Pill. STM32 tools can therefore not support this and reject a connection with it.
Solution: either ask the counterfeiters for help or get a NUCLEO, e.g. the NUCLEO-F103RB from an authorised dealer.
Hope that helps?
Good luck!
/Peter
‎2025-01-28 4:46 AM
Oops, I replied too quickly and thought you were using a Blue Pill. Hang on, let me take a closer look at your documentation.
Where did you buy the STM32F103C8T6?
/Peter
‎2025-01-28 4:52 AM
Which LED you want to flash?
I don't see any LED on PA9 that you are trying to control with your code?
‎2025-01-28 4:56 AM
Hi, the manufacturer did the assembly so I don't know where they bought it but the MCU doesn't seem to be counterfeit. It has the logo ST on it.
Jean
‎2025-01-28 5:02 AM
It is a LED connected to the pin A9 and to GND, i checked that the diode was working when connected to +3.3V to GND it is the case so the diode is not the problem.
‎2025-01-28 5:02 AM
Please see How to insert source code - not as screenshots.
@JTAPIE wrote:the simple program to blink a pin to which I attach a diode is not working   
Please show how you are attaching the LED.
"Not working" tells us little: does the LED not light at all? stay on permanently? burst into flames?
@JTAPIE wrote:Any idea of what I could look for or resources ?
Use the debugger to see what the code is actually doing.
Certainly, get the LED working before moving on to advanced stuff like USB!
‎2025-01-28 5:03 AM
@JTAPIE wrote:It is a LED connected to the pin A9 and to GND
No series resistor?
‎2025-01-28 5:10 AM
I tried with and without resistance, it's not lighting in both cases.
‎2025-01-28 5:11 AM
/* USER CODE BEGIN Header */
* @file : main.c
* @brief : Main program body
* @attention
* Copyright (c) 2025 STMicroelectronics.
* All rights reserved.
/* USER CODE END Header */
#include "main.h"
#include "usb_device.h"
/* Private includes ----------------------------------------------------------*/
/* USER CODE END Includes */
/* USER CODE BEGIN PTD */
/* USER CODE END PTD */
/* USER CODE BEGIN PD */
/* USER CODE END PD */
/* USER CODE BEGIN PM */
/* USER CODE END PM */
/* USER CODE BEGIN PV */
/* USER CODE END PV */
/* USER CODE BEGIN PFP */
/* USER CODE END PFP */
/* Private user code ---------------------------------------------------------*/
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
* @brief The application entry point.
* @retval int
int main(void)
/* USER CODE BEGIN 1 */
/* USER CODE END 1 */
HAL_Init();
/* USER CODE BEGIN Init */
/* USER CODE END Init */
SystemClock_Config();
/* USER CODE BEGIN SysInit */
/* USER CODE END SysInit */
MX_GPIO_Init();
/* USER CODE BEGIN 2 */
/* USER CODE END 2 */
/* Infinite loop */
/* USER CODE BEGIN WHILE */
while (1)
/* USER CODE END WHILE */
HAL_GPIO_WritePin(GPIOA, GPIO_PIN_9, GPIO_PIN_SET);
HAL_Delay(400);
// LED OFF
HAL_GPIO_WritePin(GPIOA, GPIO_PIN_9, GPIO_PIN_RESET);
HAL_Delay(400);
/* USER CODE BEGIN 3 */
/* USER CODE END 3 */
* @brief System Clock Configuration
* @retval None
void SystemClock_Config(void)
RCC_PeriphCLKInitTypeDef PeriphClkInit = {0};
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
RCC_OscInitStruct.HSEState = RCC_HSE_ON;
RCC_OscInitStruct.HSEPredivValue = RCC_HSE_PREDIV_DIV1;
RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL3;
Error_Handler();
RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_HSE;
if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_0) != HAL_OK)
Error_Handler();
PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_USB;
PeriphClkInit.UsbClockSelection = RCC_USBCLKSOURCE_PLL;
if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit) != HAL_OK)
Error_Handler();
* @brief GPIO Initialization Function
* @PAram None
* @retval None
/* USER CODE BEGIN MX_GPIO_Init_1 */
/* USER CODE END MX_GPIO_Init_1 */
/* GPIO Ports Clock Enable */
__HAL_RCC_GPIOD_CLK_ENABLE();
__HAL_RCC_GPIOA_CLK_ENABLE();
/*Configure GPIO pin Output Level */
/*Configure GPIO pin : PA9 */
GPIO_InitStruct.Pin = GPIO_PIN_9;
GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
/* USER CODE BEGIN MX_GPIO_Init_2 */
/* USER CODE END MX_GPIO_Init_2 */
/* USER CODE BEGIN 4 */
/* USER CODE END 4 */
* @brief This function is executed in case of error occurrence.
* @retval None
void Error_Handler(void)
/* USER CODE BEGIN Error_Handler_Debug */
/* User can add his own implementation to report the HAL error return state */
__disable_irq();
while (1)
/* USER CODE END Error_Handler_Debug */
#ifdef USE_FULL_ASSERT
* @brief Reports the name of the source file and the source line number
* where the assert_param error has occurred.
* @PAram file: pointer to the source file name
* @PAram line: assert_param error line source number
* @retval None
void assert_failed(uint8_t *file, uint32_t line)
/* USER CODE BEGIN 6 */
/* User can add his own implementation to report the file name and line number,
ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
/* USER CODE END 6 */
#endif /* USE_FULL_ASSERT */
