2015-07-23 6:17 AM
Hello! I have 13 STM32F100C8 and I see( Keil memory windows ) at 0x1FFFF7e8 (
contiguous
12 bytes) very strange ''so called'' Uniqe Ids - see below.ffff8a07ffffffffffffffff, ffff8807ffffffffffffffff , ffffa007ffffffffffffffff, ffff8407ffffffffffffffff, ffff6f07ffffffffffffffff, ffffb507ffffffffffffffff ,ffffa107ffffffffffffffff,
ffff8707ffffffffffffffff, ffff9907ffffffffffffffff,ffffa107ffffffffffffffff ,
ffff9507ffffffffffffffff, ffffa407ffffffffffffffff, ffff9807ffffffffffffffffThose IDs have a lot of ''F''s and even are duplicated within 13(!) exemplars.Please,explain the phenomenon. Thank you. Andrew #unique-id2015-07-23 7:58 AM
FAE - what is it?
http://www.indeed.com/q-Field-Application-Engineer-jobs.html
, either the Distributor's or ST's2015-07-23 9:33 AM
Hi Andrew,
We confirm that these devices are engineering samples and their production date is from Week37 2010. You need to re-contact digikey to send you new samples as replacement by an RMA process. They will escalate the samples to ST warehouses for that replacement. Cheers, {STOne -32}
