2014-05-05 08:04 AM
I'm trying to config wake up from deep sleep (STOP mode) in STM32F030 for 1350 milli seconds.I've found a way to wake up in resolution of seconds with the Alarm with the following code: RTC_TimeTypeDef RTC_TimeStructure; RTC_AlarmTypeDef RTC_AlarmStructure; secondsLoad = wakeUpCounter / ONE_SECOND; // Get current time RTC_GetTime(RTC_Format_BIN, &RTC_TimeStructure); // Set the alarm to current time + Xs RTC_AlarmStructure.RTC_AlarmTime.RTC_H12 = RTC_H12_AM; RTC_AlarmStructure.RTC_AlarmTime.RTC_Hours = RTC_TimeStructure.RTC_Hours; RTC_AlarmStructure.RTC_AlarmTime.RTC_Minutes = RTC_TimeStructure.RTC_Minutes; RTC_AlarmStructure.RTC_AlarmTime.RTC_Seconds = RTC_TimeStructure.RTC_Seconds + secondsLoad; RTC_AlarmStructure.RTC_AlarmDateWeekDay = 31; RTC_AlarmStructure.RTC_AlarmDateWeekDaySel = RTC_AlarmDateWeekDaySel_Date; RTC_AlarmStructure.RTC_AlarmMask = RTC_AlarmMask_DateWeekDay | RTC_AlarmMask_Minutes | RTC_AlarmMask_Hours; RTC_SetAlarm(RTC_Format_BIN, RTC_Alarm_A, &RTC_AlarmStructure);As well I can configure wake up with resolution of sub seconds as following: if (wakeUpCounter > secondsLoad * ONE_SECOND) { // Set AlarmA subseconds and enable SubSec Alarm : generate x interripts per Second RTC_AlarmSubSecondConfig(RTC_Alarm_A, (wakeUpCounter - secondsLoad * ONE_SECOND), 7); } But I don't know how to configure it for 1.350 sec. (or 15.56sec)Thanks you very much in advance for answer!Meir #wakeup #real-time-clock-rtc-alarm #timer #rtc #stm32
